Community
cancel
Showing results for
Search instead for
Did you mean:
Jake_S_
Linux Install System Studio 2016 libstdc++.so.6 present but not detected
$ sudo ./install.sh -v
Package id: l_pset_p_2.5.0.318, built Nov  5 2015 19:14:37
Installation fails with:
Missing critical prerequisite
-- libstdc++.so.6 library not found
However I have those libs:
$ find / -name libstdc++.so.6 2>/dev/null
/usr/lib/i386-linux-gnu/libstdc++.so.6
/usr/lib/x86_64-linux-gnu/libstdc++.so.6
/usr/lib32/libstdc++.so.6
/usr/libx32/libstdc++.so.6
APT also confirms this:
$ sudo apt-get install libstdc++6 libstdc++6:i386 libstdc++6-4.7-dev libstdc++6-4.7-dev:i386
Reading package lists... Done
Building dependency tree
Reading state information... Done
libstdc++6-4.7-dev is already the newest version.
libstdc++6-4.7-dev:i386 is already the newest version.
libstdc++6 is already the newest version.
libstdc++6:i386 is already the newest version.
0 to upgrade, 0 to newly install, 0 to remove and 247 not to upgrade.
Some information about my system:
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 14.04.3 LTS
Release:	14.04
Codename:	trusty
Jake_S_
Does no-one from intel bother to read these posts?
Yang_W_Intel
     Sorry for late response. It looks like the issue is related to the ISS installer. As a workaround, could you please try to put your libstdc++.so.6 library either to LD_LIBRARY_PATH variable of installer environment, or make a symbolic link to it in /usr/lib (/usr/lib64 depending on architecture)?
-Yang
Jake_S_
-Yang
$ LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu/ sudo ./install.sh
$ sudo ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 /usr/lib64/libstdc++.so.6
$ sudo ./install.sh
(this one worked)
Okay it worked with a symlink to /usr/lib64 (but not with LD_LIBRARY_PATH)
Yang_W_Intel
Thank you for the response. It is an issue for the prerequisites checking in the installer. Please use the symlink as the workaround. The issue will be fixed in the ISS2017 release.
Thank you.
-Yang
Alex_F_
Still not fixed in 2017.0.022
