Community
cancel
Showing results for
Search instead for
Did you mean:
Mihail_S_
Mixed Java/Native/JavaScript call stacks
I am evaluating Intel VTune Amplifier 2017 for Systems in a non-trivial scenario in which collecting mixed Java/Native (C/C++)/JavaScript call stacks on Android would give the optimal developer experience. So far, from reading the documentation I saw that it is possible to:
  • collect mixed Java/Native call stacks
  • collect JavaScript call stacks (on V8 which we use for our project)
However, it is not clear to me if it is possible to collect mixed Java/Native/JavaScript call stacks. Also, currently I test on Acer GT-810 rooted device and I observed large percentage (66-75%) of unsuccessfully unwinded call stacks. I guess this is due to the fact that V8 JIT compiler uses different calling convention but it might be well the fact that I am using unsuitable Android device. In that regards I would like to know what are the recommended Android devices and if there are Intel provided images. Any links to further resources will be appreciated.
TIA,
Mihail
