Community
cancel
Showing results for
Search instead for
Did you mean:
Prasad__Nagendra
Problem in setting up License server for Intel System Studio
I installed the License server on RedHat7.6.0.
And started License server using the license file generated for the serial number FST9-FRS6C7JL (for Intel system studio ultimate), Not able to connect from the client.
I tried disabling the firewall service on RedHat but not helped.
I started License server with
1)SERVER localhost a0c5891d5e57 27009
VENDOR INTEL PORT=28519
Please find attached log file log_27009.txt
result: I am not able to see tcp port running(used nmap localhost) And from the client not able to connect.
2)SERVER localhost a0c5891d5e57 9002
VENDOR INTEL PORT=9006
Please find attached log file log_9002.txt
result: I am able to see tcp port running(used nmap localhost) And from the client not able to connect.
any help is appreciated..
