Intel® System Studio
Ask questions and share information with other users of the Intel® System Studio.
Intel® System Studio components are now transitioned to several Intel® oneAPI toolkits and can be found under Intel oneAPI Base Toolkit and Intel oneAPI IoT Toolkit. Use the respective forums for questions related to these components. Getting Started questions can be asked in the Registration, Download, Licensing and Installation forum. If you have Priority Support you can submit your question in the Online Service Center.
346 Discussions
Problem with installation of ISS components
Jacek_J_1
I followed the instructions from the link https://software.intel.com/en-us/installing-the-intel-system-studio-iot-edition to install the ISS for my galileo board. The problem appears for Java SE Dev Kit 8 - I have 32-bit Windows 7 whereas the x64 JDK is needed. 32-bit JDK does not work for ISS while I cannot install x64 JDK on my system. Is there any solution to this common (I suppose...) problem?
Thank you in advance!
JJ
