I came to the BBS for the first time, if the post does not conform to the requirements, please let us know, thanks! About this plate, I have read introduction.
PC-Environments: hp computer, CPU——Intel Core i5 4 core,Memory——8G, OS——CentOS 7, use miniconda3(Python3.6) as virtualenv environment, numpy I compiled from source code.
I have installed Intel® System Studio Ultimate Edition 2017, so I have gotten MKL library. In order to make environments clean and tidy, I copy it to /tmp/mkl-nfs/lib directory.
According to Intel-DOC[https://software.intel.com/en-us/node/528514], mkl_rt(SDL) automatically links interface, threading, and computational libraries, but I use sample code to look, something else happened.
$ tail numpy/site.cfg #[fftw] #libraries = fftw3 # # For djbfft, numpy.distutils will look for either djbfft.a or libdjbfft.a . #[djbfft] #include_dirs = /usr/local/djbfft/include #library_dirs = /usr/local/djbfft/lib [mkl] library_dirs = /tmp/mkl-nfs/lib mkl_libs = mkl_rt $ python >>> import numpy as np >>> np.show_config() blas_mkl_info: libraries = ['mkl_rt', 'pthread'] library_dirs = ['/tmp/mkl-nfs/lib'] define_macros = [('SCIPY_MKL_H', None), ('HAVE_CBLAS', None)] include_dirs = ['/usr/local/include', '/usr/include', '/usr/local/miniconda3/envs/perinfoMKL1/include'] blas_opt_info: libraries = ['mkl_rt', 'pthread'] library_dirs = ['/tmp/mkl-nfs/lib'] define_macros = [('SCIPY_MKL_H', None), ('HAVE_CBLAS', None)] include_dirs = ['/usr/local/include', '/usr/include', '/usr/local/miniconda3/envs/perinfoMKL1/include'] lapack_mkl_info: libraries = ['mkl_rt', 'pthread'] library_dirs = ['/tmp/mkl-nfs/lib'] define_macros = [('SCIPY_MKL_H', None), ('HAVE_CBLAS', None)] include_dirs = ['/usr/local/include', '/usr/include', '/usr/local/miniconda3/envs/perinfoMKL1/include'] lapack_opt_info: libraries = ['mkl_rt', 'pthread'] library_dirs = ['/tmp/mkl-nfs/lib'] define_macros = [('SCIPY_MKL_H', None), ('HAVE_CBLAS', None)] include_dirs = ['/usr/local/include', '/usr/include', '/usr/local/miniconda3/envs/perinfoMKL1/include'] >>> np.__version__ '1.13.0.dev0+4408f74' >>>
Below followings is test.py code:
#!/usr/local/miniconda3/envs/perinfoMKL0/bin/python # -*- coding: utf-8 -*- import numpy as np import time start_time = time.time() a = 10 ** 4 A = np.random.random((a, a)) B = np.random.random((a, a)) C = A.dot(B) print("Time: ", time.time() - start_time)
And then, I do execute it code use command:
$ LD_DEBUG=files ./test.py 2> files.log $ grep "libmkl_rt.so" files.log 24311: file=libmkl_rt.so [0]; needed by /home/yancy/.conda/envs/perinfoMKL/lib/python3.6/site-packages/numpy-1.13.0.dev0+1a9f43f-py3.6-linux-x86_64.egg/numpy/core/multiarray.cpython-36m-x86_64-linux-gnu.so [0] 24311: file=libmkl_rt.so [0]; generating link map 24311: calling init: /tmp/mkl-nfs/lib/libmkl_rt.so 24311: file=/tmp/mkl-nfs/lib/libmkl_core.so [0]; dynamically loaded by /tmp/mkl-nfs/lib/libmkl_rt.so [0] <========== 24311: file=/tmp/mkl-nfs/lib/libiomp5.so [0]; dynamically loaded by /tmp/mkl-nfs/lib/libmkl_rt.so [0] <========== 24311: file=/tmp/mkl-nfs/lib/libmkl_intel_thread.so [0]; dynamically loaded by /tmp/mkl-nfs/lib/libmkl_rt.so [0] <========== 24311: file=/tmp/mkl-nfs/lib/libmkl_intel_lp64.so [0]; dynamically loaded by /tmp/mkl-nfs/lib/libmkl_rt.so [0] <========== 24311: calling fini: /tmp/mkl-nfs/lib/libmkl_rt.so [0] $ grep "libmkl_avx2.so" files.log 24311: file=/tmp/mkl-nfs/lib/libmkl_avx2.so [0]; dynamically loaded by /tmp/mkl-nfs/lib/libmkl_core.so [0] 24311: file=/tmp/mkl-nfs/lib/libmkl_avx2.so [0]; generating link map 24311: file=/tmp/mkl-nfs/lib/libmkl_intel_thread.so [0]; needed by /tmp/mkl-nfs/lib/libmkl_avx2.so [0] (relocation dependency) 24311: file=/tmp/mkl-nfs/lib/libmkl_core.so [0]; needed by /tmp/mkl-nfs/lib/libmkl_avx2.so [0] (relocation dependency) 24311: calling init: /tmp/mkl-nfs/lib/libmkl_avx2.so 24311: opening file=/tmp/mkl-nfs/lib/libmkl_avx2.so [0]; direct_opencount=1 24311: calling fini: /tmp/mkl-nfs/lib/libmkl_avx2.so [0]
Now, we can see interface, threading, and computational run-time libraries (RTL) libraries all loaded by mkl_rt. So, I am confused it, this output is different from Intel-DOC. I see relocation dependency output, but I am hard to undertstand. Someone can explain it, I am grateful to you. Again thanks.
Hi Yan,
Thank you a lot for the sharing in https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/733207.
Here the step is expected. :
The Single Dynamic Library (SDL) automatically links interface, threading, and computational libraries and thus simplifies linking
07 |
24311: file =/tmp/mkl-nfs/lib/libiomp5.so [0]; dynamically loaded by /tmp/mkl-nfs/lib/libmkl_rt.so [0] <========== |
08 |
24311: file =/tmp/mkl-nfs/lib/libmkl_intel_thread.so [0]; dynamically loaded by /tmp/mkl-nfs/lib/libmkl_rt.so [0] <========== |
09 |
and second step: libmkl_avx2.so (processor-optimized) libraries were loaded by libmkl_core.so . which is expected.
The last message seems caused the confusion. what is exactly of means "libmkl_intel_thread.so needed by libmkl_avx2.so" relocation dependency ? I will check with internal team and see if any more ideas.
Ying
file
15 |
Hi, Ying:
Thanks your sincere helping. Ok, I will be look forward to your reply. If you want to some data and test-code and even some things, please let me know.
Best, yancy.
