Community
cancel
Showing results for
Search instead for
Did you mean:
Prasad__Nagendra
Should I reinstall openvino,gstreamer..etc for intel c++ compiler
I am using gcc,g++ compilers to compile my code, and dependent libs such as openvino,gstreamer etc.
Now i want to compile my code using intel c++ to get some performance benefit on intel platforms.
For that should I reinstall/recompile the dependent libs like openvino,gstreamer??
Hi Nagendra,
In case of OpenVINO, it already has performance libraries and it is independent with ICC. So, no need to recompile or reinstall.
For gstreamer, I will confirm back with you. If I'm not mistaken, gstreamer may have some Intel performance libraries and it can be compiled by ICC and GCC. So no need to reinstall them due to ICC.
