Community
cancel
Showing results for
Search instead for
Did you mean:
Siddhesh_S_Intel
Soc Watch on Linux
I have installed System Studio 2016 on my Ubuntu 14.04 Skylake board. When I run the socwatch command as per https://software.intel.com/en-us/node/591968, to be specific:
>./socwatch -t 60 -f cpu-cstate -m -r vtune -o ./results/test
 I get the below message:
open error in config_i: No such file or directory
ERROR: immediate read failed: couldn't initialize driver connection
FATAL: ERROR retrieving platform name
FATAL: ERROR running collection
ERROR: ERROR working controller!
ERROR: ERROR running controller!
The SOCWatchConfig.txt file is present in the working directory. I have build the drivers as per the instruction guide. Any help would be greatly appreciated.
Mostafa_M_1
Did you find out a solution for this please ?
Siddhesh_S_Intel
Hey,
I had some weird issues while running on Ubuntu 14.04 Skylake board. I had got it working on the Broadwell platform though. But unfortunately I don't exactly remember the steps I had taken to debug this. What I weakly remember is to follow the steps mentioned in the manual to build the drivers.
Sorry couldn't be of much help.
Yang_W_Intel
Please check first if the driver is built and installed successfully before you use the socwatch. The instructions for driver setup is here: https://software.intel.com/en-us/driver_setup_for_energy_analysis
I would also recommend to upgrade the product to the latest Intel system studio 2017 update 1 release. If you still got the problem, please let me know your exact CPU configs (e.g. output from lscpu). Some of the CPU type may still only be supported under NDA.
-Yang
