Community
cancel
Showing results for
Search instead for
Did you mean:
ZVere
System studio 2018: GXX_ROOT
In my linux host I have a g++ compiler created with crosstool-ng
This is the g++ I want icpc to use, not the default one.
So I ran:
export GXX_ROOT=/my_toolchain/release/bin
export GXX_INCLUDE=/my_toolchain/release/x86_64-unknown-linux-gnu/include/c++/6.3.0
export SYSROOT= /my_toolchain/release/x86_64-unknown-linux-gnu/sysroot
export GNU_PREFIX=x86_64-unknown-linux-gnu-
The GXX_ROOT contains the g++ compiler:  x86_64-unknown-linux-gnu-g++
But upon runnning the linker, it seems icpc still uses the default g++ installed in the host.
In my case, the host has no g++.
So I got the error:
Requires 'install path' setting gathered from g++
Can you please help ?
Thank you,
Zvika
ZVere
I made a little progress.
Now I got an error message in the link phase:
x86_64-unknown-linux-gnu-ld: No such file or directory
How can I tell icpc where to look for x86_64-unknown-linux-gnu-ld ?
Thank you,
Zvika
ZVere
I updated PATH and now it contains the path to :
Now I got the error message:
x86_64-unknown-linux-gnu-ld.bfd: cannot find -lgcc
Thank you,
Zvika
ZVere
In the link phase I added:
-L/my_toolchain/release/lib/gcc/x86_64-unknown-linux-gnu/6.3.0
This folder contains libgcc.a
Is this the right solution ?
Thank you,
Zvika
