Community
cancel
Showing results for
Search instead for
Did you mean:
Yu__Xiao
There is a problem installing Intel® System Studio 2019 Update 2 under Windos7
After installing Intel® System Studio 2019 Update 2 under Window 7, there was an error when running Intel® System Studio 2019:
11:54:07 [INFO ] TcaServer: Establish link to Server.
11:54:16 [INFO ] Using System Trace installation from 'C:\IntelSWTools\system_studio_2019\\system_debugger_2019\system_trace'.
11:54:16 [INFO ] TcaServer: Change server state: Waiting.
11:54:16 [INFO ] TCA-Server (process): Start internal daemon.
11:54:16 [INFO ] TCA-Server (process): Using configuration file located in: C:\Users\Administrator\AppData\Roaming\.tca\3\config.json
11:54:16 [ERROR] TCA-Server (process):
11:54:16 [INFO ] TCA-Server (process): Internal daemon stopped.
11:54:18 [INFO ] TCA-Server (process): Start internal daemon.
11:54:18 [INFO ] TCA-Server (process): Using configuration file located in: C:\Users\Administrator\AppData\Roaming\.tca\3\config.json
11:54:18 [ERROR] TCA-Server (process):
11:54:19 [INFO ] TCA-Server (process): Internal daemon stopped.
11:54:21 [ERROR] TcaServer: Could not find supported TCA-Server.
Reason:
The TCA-Server had been successfully restarted, but hasn't shown up. Check the log if the TCA Server was properly restarted.
Hint:
TCA requires (local) network access, please verify your firewall configuration and approve the "tca-server" application.
TCA uses UDP broadcasts on port 1534, please verify that this port is not in use by any other non-TCF application.
VPN clients may prevent any usage of UDP broadcasts, please verify that no VPN client is in use.
11:54:21 [INFO ] TCA-Server (process): Using configuration file located in: C:\Users\Administrator\AppData\Roaming\.tca\3\config.json
11:54:21 [ERROR] TCA-Server (process):
11:54:21 [INFO ] TCA-Server (process): Internal daemon stopped.
Error: TCA-Server can't start; how to solve it?
Yu__Xiao
Thank you for your reply! Starting Intel System Studio as an administrator still has the same problem.
Yu__Xiao
Reinstall Intel® System Studio 2019 Update 2
After that, try again in the same way, and the same problem still occurs. Check C:\Users\Administrator\AppData\Roaming\.tca\3\ without the config.json configuration file.
