Community
cancel
Showing results for
Search instead for
Did you mean:
sunil_s_
Unable to Register component on iotkit dash board
Hi ,
I have register intel galileo on iotkit dashboard but not able to register component.
I am using following command :
iotkit-admin register <comp_name> <catalogid> which I get from
https://github.com/enableiot/iotkit-agent/blob/master/README.md#5-notes-about-admin-commands
After hitting this command I am getting following error:
2014-02-20T22:22:54.624Z - info: Starting registration ...
2014-02-20T22:22:55.082Z - info: Activating ...
2014-02-20T22:23:02.436Z - error: Activation Rejected:  {"code":1410,"message":"Invalid Activation Code"}  --> error
2014-02-20T22:23:02.454Z - error: Error in the registration process ... 300
Can any one please help me out ?
Sunil
Looks like your board is not activated yet.
In Add/Edit device section, you will have to enter the device id of your board. you can get the device id by using following command on the board.
iotkit-admin device-id
Enter the device id in the cloud. after that, it will privde an activation code for your device.
in your board enter following command
iotkit-admin activate <activation code from cloud>
after this step, you register your component.
Ural
