Community
cancel
Showing results for
Search instead for
Did you mean:
Larry_Osborn
Which Macraigor probe connects to Intel System Studio
Which Macraigor probe connects to the ISS? and how do I connect this probe once I have it?
Robert_M_Intel1
Hi Larry,
the device is the following: http://www.macraigor.com/usbDemon.htm (Macraigor usb2Demon). The Intel Architecture version comes with different adapters. The most common adapter the compatible with the 60-pin eXtended Debug Port (XDP) spec, but you may want to check your platform if it uses a 24 or 31 pin adapter instead.
Let me also state that the Macraigor usb2Demon only supports the following platforms with the Intel(R) System Debugger:
Intel® Atom™ Processor E600, N2000, Z500, Z600, Z2400, Z2500, Z2700, CE4100, CE4200, CE5300
Intel® Puma™ 6 Media Gateway
For any other targets you will require the Intel(R) ITP-XDP 3BR device: https://designintools.intel.com/product_p/itpxdp3brext.htm
Please feel free to ask follow up questions.
Thanks, Rob
