Intel® System Studio
Ask questions and share information with other users of the Intel® System Studio.
Zephyr Static_lib example not compiling
Mateo_G_Intel
Hello, I am using ISS 2016 update 2.
I detected that the Static_lib example does not compiles:
- Create a new Project for Microcontrollers for Intel(r) Quark(tm) SE c1000 Developer Board
- Select Zephyr Project [1.7.0]
- Select Core: Intel(r) Quark(tm), Toolchain: Intel(r) System Studio for Microcontrollers - GCC IA Compiler
- Select Example: Tools > Static_lib
When you build the project you will receive errors of architecture incompatibility.
Eg:
/home/intel/iss_workspace/Static_lib_2/zephyr/Makefile:853: recipe for target 'zephyr_prebuilt.elf' failed
/opt/intel/issm_2016.2.085/tools/compiler/gcc-ia/5.2.1/bin/../lib/gcc/i586-intel-elfiamcu/5.2.1/../../../../i586-intel-elfiamcu/bin/ld: skipping incompatible /home/intel/iss_workspace/Static_lib_2/hello_world/outdir/qemu_x86/mylib/lib/libmylib.a when searching for -lmylib
make[3]: Leaving directory '/home/intel/iss_workspace/Static_lib_2/hello_world/outdir/qemu_x86'
/opt/intel/issm_2016.2.085/tools/compiler/gcc-ia/5.2.1/bin/../lib/gcc/i586-intel-elfiamcu/5.2.1/../../../../i586-intel-elfiamcu/bin/ld: cannot find -lmylib
Makefile:173: recipe for target 'sub-make' failed
/opt/intel/issm_2016.2.085/tools/compiler/gcc-ia/5.2.1/bin/../lib/gcc/i586-intel-elfiamcu/5.2.1/../../../../i586-intel-elfiamcu/bin/ld: skipping incompatible /opt/intel/issm_2016.2.085/tools/compiler/gcc-ia/5.2.1/lib/gcc/i586-intel-elfiamcu/5.2.1/libgcc.a when searching for -lgcc
/opt/intel/issm_2016.2.085/tools/compiler/gcc-ia/5.2.1/bin/../lib/gcc/i586-intel-elfiamcu/5.2.1/../../../../i586-intel-elfiamcu/bin/ld: skipping incompatible /opt/intel/issm_2016.2.085/tools/compiler/gcc-ia/5.2.1/bin/../lib/gcc/i586-intel-elfiamcu/5.2.1/libgcc.a when searching for -lgcc
/opt/intel/issm_2016.2.085/tools/compiler/gcc-ia/5.2.1/bin/../lib/gcc/i586-intel-elfiamcu/5.2.1/../../../../i586-intel-elfiamcu/bin/ld: cannot find -lgcc
collect2: error: ld returned 1 exit status
The hello_world program seems to be compiled with the wrong BOARD configuration. This error can be fixed by changing the target BOARD of the Makefile inside hello_world
- BOARD = qemu_x86
+ BOARD = quark_se_c1000_devboard
Can you please verify if this is a real issue?
Mateo
Richard_A_Intel
Mateo,
I tested the Static_lib samples and saw the issue you reported with the board name being set incorrectly and the build failing.
When testing the workaround you provided I still saw issues with the build of the sample after changing the Makefile in the hello directory of the project to replace the line:
BOARD = qemu_x86
With:
but it did seem to resolve most of the errors related to this build.
Thank you for reporting this and providing the workaround.
Richard
