Intel® System Studio
Ask questions and share information with other users of the Intel® System Studio.
Intel® System Studio components are now transitioned to several Intel® oneAPI toolkits and can be found under Intel oneAPI Base Toolkit and Intel oneAPI IoT Toolkit. Use the respective forums for questions related to these components. Getting Started questions can be asked in the Registration, Download, Licensing and Installation forum. If you have Priority Support you can submit your question in the Online Service Center.
346 Discussions
bugreport: installer: missing dependency to "which"
Josef_D_
when installing ISS from "system_studio_2019_ultimate_edition_offline.tar.gz" offline installer without "which" tool installed on Centos7.5, following error will appear, even if "cpio" is installed. "which" (which-2.20-7.el7.x86_64) tool installation will fix the problem.
There are one or more critical unresolved issues which prevent setup from
continuing.  Fix them and run the setup program again.
Missing critical prerequisite
-- 'cpio' tool could not be found
The setup program requires 'cpio' tool to complete installation. Please make
sure this tool is installed and its location is present in 'PATH' environment
variable.
expected behavior:
* installer will check if "which" tool is present
reproducible on:
centos7.5 without which rpm installed (typical in some container environments)
Tom_Ingleby_Intel
Hay Juhi,
I've also seen this on other Intel Software installers.
-Tom
