Community
cancel
Showing results for
Search instead for
Did you mean:
MHamd2
cannot install Intel System Studio in windows 10
hai, i have a problem with the installation this is on Asus Intel i5, RAM 4GB, Windows 10 Pro i already install Docker for windows but the docker cannot start and then in Intel System Studio : Intel® System Studio IoT Edition Setup Wizard ended prematurely because of an error(s). Can't load image: An error occurred trying to connect: Post http://%2F%2F.%2Fpipe%2Fdocker_engine/v1.24/images/load?quiet=1: open //./pipe/docker_engine: The system cannot find the file specified. finished with error 1   To install this program at a later time, run Setup Wizard again. Click the Finish button to exit the Setup Wizard. what should i do to fix the problem?
Jing_X_Intel
According to the error message, it is most likely caused by docker. Could you try to install it again after the docker becomes functioning?
MHamd2
