Intel® System Studio
Ask questions and share information with other users of the Intel® System Studio.
Intel® System Studio components are now transitioned to several Intel® oneAPI toolkits and can be found under Intel oneAPI Base Toolkit and Intel oneAPI IoT Toolkit. Use the respective forums for questions related to these components. Getting Started questions can be asked in the Registration, Download, Licensing and Installation forum. If you have Priority Support you can submit your question in the Online Service Center.
346 Discussions
intermittent error at runtime "Unable to load function: RegQueryValueExA (ADVAPI32.dll)"
Newell__Glenn
My app works fine otherwise. On some machines the error happens almost always, on others only rarely.
My target platform is Windows 10 and I get the same behavior with Windows 8.1 or either of two windows 10 SDKs.
It seems to stop if I run the app in Windows 8 compatibility mode (even when using a windows 10 SDK).
The error always happens when running the release app in the MS VS 2017 debugger, until I enabled mixed mode debugging, then I don't see the error (so far).
The app is C/C++ CLI with some windows functions. The code is not managed.
Google searching turns up nothing?
Any ideas? Seems like a compiler/linker or OS problem?
System Studio 19 latest with Intelc++, IPP and TBB. MS VS2017.
The registry reading code is from an MS example.
Newell__Glenn
But it is intermittent for the same user. Sometimes it works, sometimes it doesn't, on the same PC in subsiquent runs with identical inputs.
