Community
cancel
Showing results for
Search instead for
Did you mean:
mo_bri
qm_adc.o Missing windows 10
fails to build the example for the acceleromator...
Windows 10 - Running latest Eclipse version., this is after I spend an hour getting over the Java not 1.7+ supported, even though I had 1.8 64 bit installed. (for this I changed the bat file to not even bother looking it the java -version is ok)
But now problem number 2 - already !!!!
18:04:43 **** Build of configuration build_debug for project acceleromator ****
make
APP_NAME = acceleromator
SOC = quark_d2000
APP_DIR = .
BUILD = debug
make -C ./bsp/drivers SOC=quark_d2000
BUILD = debug
make[1]: Entering directory `C:/IntelSWTools/ISSM_2016.0.027/workspace/acceleromator/bsp/drivers'
i586-intel-elfiamcu-gcc -O0 -g -DDEBUG -std=c90 -Wall -Wextra -Werror -Wno-unused-parameter -fmessage-length=0 -I../include -fno-asynchronous-unwind-tables -I../drivers -I../drivers/include -march=lakemont -mtune=lakemont -miamcu -msoft-float -DSPI_IRQ_MST -I../soc/quark_d2000/include -c -o ../drivers/debug/quark_d2000/obj/qm_adc.o ../drivers/qm_adc.c
Assembler messages:
Fatal error: can't create ../drivers/debug/quark_d2000/obj/qm_adc.o: No such file or directory
make[1]: *** [../drivers/debug/quark_d2000/obj/qm_adc.o] Error 1
make[1]: Leaving directory `C:/IntelSWTools/ISSM_2016.0.027/workspace/acceleromator/bsp/drivers'
make: *** [libqmsi] Error 2
18:04:44 Build Finished (took 1s.391ms)
