Intel® System Studio
Ask questions and share information with other users of the Intel® System Studio.
Intel® System Studio components are now transitioned to several Intel® oneAPI toolkits and can be found under Intel oneAPI Base Toolkit and Intel oneAPI IoT Toolkit. Use the respective forums for questions related to these components. Getting Started questions can be asked in the Registration, Download, Licensing and Installation forum. If you have Priority Support you can submit your question in the Online Service Center.
regarding redboot installation
sindhura123
hello,
I have followed the steps for installing Redboot in CE 4100 SDK(Videon Central) on my host machine. When i build that redboot build scripts i got following error message. pls suggest the correct way.
asindhura@......:~/Intelcesdk/IntelCE-18.250447/project_build_i686/IntelCE/redboot-18.3.10462.224519/redboot/redboot_build_scripts$ sh clean_and_rebuild_redboot.sh
ERROR: i386-elf-gcc not found in path, please install the toolchain correctly!
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
See release notes for details.
Robert_M_Intel1
Dear Sindhura,
the CE SDK and it's software stack are supported directly by Videon Central. They will contact you and respond shortly.
Thanks, Rob
