Community
cancel
Showing results for
Search instead for
Did you mean:
eric_s_3
source ./inspxe-genvars.sh warning
HI,
On an Atom E6xx running WR Linux 4.2.0.0, with Inspector CL tools installed, running the command,
results in the following warning:
  dirname: invalid option -- 'b'
Is this anything to be concerned about (I am running a target app using inspxe-cl)?
Thank you.
ES.
Mark_D_Intel
The inspxe-genvars.sh script should not be executed via 'source' - it should run in another shell (which happens automatically when run as ./inspxe-genvars.sh).  It creates the inspxe-vars.sh/csh scripts that should be called with 'source'  to set up the environment.
