Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
314 Discussions
Don't source oneapi setvars
Jakub_H
Hi.
I just started working with the Tiber developer cloud. I am connecting via VS Code and using the training nodes.
I noticed, that after opening the terminal, the PATH, CPATH, LIBRARY_PATH, LD_LIBRARY_PATH environment variables are already filled with paths to oneapi tools and libraries. It seems like the /opt/intel/oneapi/setvars.sh is being sourced somewhere.
How do I make it such that it is not sourced?
I would like to setup the environment myself, try different versions, test my compilation trajectory when intel tools are not found, etc., so I would like my environment clean after login. But also don't want to completely clear the env vars, just don't initialize anything intel.
I looked in .bashrc and some similar files in /etc, but could not find how the intel environment gets there.
Is it possible, or is it hard-baked in some files I don't have privileges to access?
Jakub
Thivagar_Intel
Hi Jakub_H,
We apologize for the inconvenience. Unfortunately, the Intel® Tiber™ Developer Cloud instances use a pre-built Golden image with fixed environment variables. As a result, we cannot modify the environment setup or use a different image, and therefore, we are unable to provide an unconfigured environment as requested.
Thivagar
Thivagar_Intel
Hi Jakub_H,
Please specify which Developer Cloud product you are encountering issues with. Is it Intel® Developer Cloud, Intel® Developer Cloud for the Edge, or Intel® Tiber™ Developer Cloud for oneAPI?
Thivagar
Jakub_H
Thivagar_Intel
Hi Jakub_H,
Thivagar
Jakub_H
ok, thank you for the informaton.
Jakub
Thivagar_Intel
Hi Jakub_H,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Thivagar
