Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
328 Discussions
Error importing intel_extension_for_pytorch in Simple LLM Inference notebook
cboiteux
I have installed IPEX and I ran the following code:
!pip3 install torch
!pip3 install intel_extension_for_pytorch
import logging
import os
import random
import re
os.environ["SYCL_PI_LEVEL_ZERO_USE_IMMEDIATE_COMMANDLISTS"] = "1"
os.environ["ENABLE_SDP_FUSION"] = "1"
import warnings
# Suppress warnings for a cleaner output
warnings.filterwarnings("ignore")
import torch
import intel_extension_for_pytorch as ipex
from transformers import AutoModelForCausalLM, AutoTokenizer
from transformers import LlamaTokenizer, LlamaForCausalLM
from transformers import BertTokenizer, BertForSequenceClassification
from ipywidgets import VBox, HBox, Button, Dropdown, IntSlider, FloatSlider, Text, Output, Label, Layout
import ipywidgets as widgets
from ipywidgets import HTML
# random seed
if torch.xpu.is_available():
    seed = 88
    random.seed(seed)
    torch.xpu.manual_seed(seed)
    torch.xpu.manual_seed_all(seed)
def select_device(preferred_device=None):
    Selects the best available XPU device or the preferred device if specified.
    Args:
        preferred_device (str, optional): Preferred device string (e.g., "cpu", "xpu", "xpu:0", "xpu:1", etc.). If None, a random available XPU device will be selected or CPU if no XPU devices are available.
    Returns:
        torch.device: The selected device object.
    try:
        if preferred_device and preferred_device.startswith("cpu"):
            print("Using CPU.")
            return torch.device("cpu")
        if preferred_device and preferred_device.startswith("xpu"):
            if preferred_device == "xpu" or (
                ":" in preferred_device
                and int(preferred_device.split(":")[1]) >= torch.xpu.device_count()
                preferred_device = (
                    None  # Handle as if no preferred device was specified
            else:
                device = torch.device(preferred_device)
                if device.type == "xpu" and device.index < torch.xpu.device_count():
                    vram_used = torch.xpu.memory_allocated(device) / (
                        1024**2
                    )  # In MB
                    print(
                        f"Using preferred device: {device}, VRAM used: {vram_used:.2f} MB"
                    return device
            device_id = random.choice(
                range(torch.xpu.device_count())
            )  # Select a random available XPU device
            device = torch.device(f"xpu:{device_id}")
            vram_used = torch.xpu.memory_allocated(device) / (1024**2)  # In MB
            print(f"Selected device: {device}, VRAM used: {vram_used:.2f} MB")
            return device
    except Exception as e:
        print(f"An error occurred while selecting the device: {e}")
    print("No XPU devices available or preferred device not found. Using CPU.")
Error: /opt/intel/oneapi/intelpython/envs/pytorch-gpu/lib/python3.9/site-packages/oneccl_bindings_for_pytorch/lib/liboneccl_bindings_for_pytorch.so: undefined symbol: _ZN3c106DeviceC1ERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE
Zulkifli_Intel
Hi cboiteux,
Thank you for reaching out.
Have you run any training from Training and Workshops? And which kernel did you use?
There is a discussion about this issue here that you can look at.
Zul
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
