Hi.
I am trying to run ipex_llm[xpu] in Jupyterlab notebook using the shared environment for learning.
I have installed ipex_llm and oneAPI using pip based on the official guide: https://github.com/intel/ipex-llm/blob/main/docs/mddocs/Overview/install_gpu.md
I am encountering the following error when trying to run "from ipex_llm.transformers import AutoModelForCausalLM":
Attached is the PDF export of the notebook that I used, showing the full output of the cells. Any advice on this would be much appreciated.
Thank you.
Hi ReubenLim,
We have informed the relevant team about this issue for further investigation and will update you as soon as possible.
Luwe
