Hi sanket98a,
For your information, the Intel® Developer Cloud Jupyter notebook instance does not have sudo system access as it is a shared system and not a virtualized system.
I will inform the relevant team regarding your request in opening the ports and will get back to you later. Thank you for your patience.
Ezza
Hi sanket98a,
Unfortunately, root access is not available to users for the Intel Developer Cloud Jupyter Notebook system. Root access are only available in the Bare Metal and Virtual Machine instances. As a workaround, we recommend that you deploy applications that do not require root access.
Ezza
Hi sanket98a,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Ezza
