Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
314 Discussions
ImportError: libintel-ext-pt-gpu.so - undefined symbol _ZNK5torch8autograd4Node4nameB5cxx11Ev
SantoshKV
Hi, While trying the MLOps Professional videos training in the Optimization part, I confronted the below error:
(pytorch) u2b13adf8e82d2463fab7667f346d3c8@idc-beta-batch-pvc-node-10:~$ python IntelPyTorch_Optimizations.py -dtype "fp32"
Traceback (most recent call last):
File "/home/u2b13adf8e82d2463fab7667f346d3c8/intel-mlops-course/MLOps_Professional/lab5/sample/IntelPyTorch_Optimizations.py", line 15, in <module>
import intel_extension_for_pytorch as ipex
File "/opt/intel/oneapi/intelpython/latest/envs/pytorch-gpu/lib/python3.9/site-packages/intel_extension_for_pytorch/__init__.py", line 93, in <module>
from .utils._proxy_module import *
File "/opt/intel/oneapi/intelpython/latest/envs/pytorch-gpu/lib/python3.9/site-packages/intel_extension_for_pytorch/utils/_proxy_module.py", line 2, in <module>
import intel_extension_for_pytorch._C
ImportError: /opt/intel/oneapi/intelpython/latest/envs/pytorch-gpu/lib/python3.9/site-packages/intel_extension_for_pytorch/lib/libintel-ext-pt-gpu.so: undefined symbol: _ZNK5torch8autograd4Node4nameB5cxx11Ev
SantoshKV
Hello Atirah,
I think I have found a workaround. I am running/rebuilding the libraries as mentioned in the Github link and also tried to use the
pip install --pre --upgrade bigdl-llm[xpu_2.1] -f https://developer.intel.com/ipex-whl-stable-xpu from the https://bigdl.readthedocs.io/ site. I have to run this on all the jupyter notebooks in the MLOps_Professional Labs -> change the kernels to `base` and follow the above.
It is a lot of hassle, but atleast I got it working. I hope the engineering team takes cognizance of this.
Thank you.
Athirah_Intel
Hi SantoshKV,
We have informed the relevant team about this issue for further investigation and will update you as soon as possible.
Athirah
Athirah_Intel
Hi SantoshKV,
We just got an update from the relevant team regarding this issue.
Please share the specific part in the video that you're having the error so that we can investigate this issue further.
On another note, we found a similar issue from Github that might help you with the error:
 https://github.com/intel/intel-extension-for-pytorch/issues/317
Athirah
SantoshKV
Hello Atirah,
Thank you for checking. I am attaching the screenshot files for better understanding.
I do get this error in the environment as well, also the when running the JupyterLab environments launched from the "Training and Workshops".
Please suggest how to proceed.
Thank you
Athirah_Intel
Hi SantoshKV,
Thank you for sharing the screenshots.
For clarification purposes, does the error persist after building IPEX from source as suggested in the Github thread shared previously?
python -m pip install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cpu
python -m pip install --trusted-host pytorch-extension.intel.com intel_extension_for_pytorch --extra-index-url https://pytorch-extension.intel.com/release-whl/stable/cpu/us/
Athirah
SantoshKV
Hey Atirah,
I'm not sure of this, but I see the same problem everywhere, I hope you have seen the screenshots too. I get the same with the pre-built notebooks with the kernels developed already too.
Please help.
Thank you.
Athirah_Intel
Hi SantoshKV,
Athirah
SantoshKV
Hello Atirah,
Thank you.
