We're trying to set up an internal web application in Dev Cloud, so we would like to know how to expose port 443/80 to Intel network. Thanks.
Hi VincentWMao,
Network configuration can only be performed by the engineering team. You can private message me (Nurul_Intel) with your request to open the port, as shown in the picture below. I'll escalate your request to the relevant team for further action.
Nurul
Hi VincentWMao,
We are checking this issue with the engineering team for further investigation and will update you as soon as possible.
Athirah
Hi VincentWMao,
Thank you for your patience.
We received an update from the engineering team that you will have to specify an IP or IP range from what access should be granted, depending on what and how many people should have this access. Therefore, kindly update us if you have the relevant information.
Athirah
Hi VincentWMao,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Athirah
