Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
329 Discussions
Issue Installing Intel Ipex Extension on GPU Instance
Nate_
Hi. I'm currently having an issue installing Ipex/pytorch extensions for GPU that I wasn't having prior. Using version 2.1 is the CPU version according to the GitHub page, so that won't solve this.
The following code is how I have been installing it in the past, and as far as I can see on the intel Github it is the most current version listed. As recently as last week this was still behaving as expected.
code:
python -m pip install torch==2.0.1a0 torchvision==0.15.2a0 intel_extension_for_pytorch==2.0.110+xpu -f https://developer.intel.com/ipex-whl-stable-xpu
I saw a note that said temporarily it needs to be torch 2.1 but that doesn't solve the issue. It is still giving me an error of:
Defaulting to user installation because normal site-packages is not writeable
Looking in links: https://developer.intel.com/ipex-whl-stable-xpu
ERROR: Could not find a version that satisfies the requirement intel_extension_for_pytorch==2.0.110+xpu (from versions: 2.0.0, 2.0.100, 2.1.0)
ERROR: No matching distribution found for intel_extension_for_pytorch==2.0.110+xpu
The instance is bare metal with the following specs:
Intel® Max Series GPU (PVC) on 4th Gen Intel® Xeon® processors – 1100 series (4x)
Ubuntu
If someone can let me know what has changed, so I can correct my approach that would be appreciated.  Thank you!
Nate_
Hi. That didn't fix it, but I was given a solution by an Intel Engineer that I will share here in case this helps anyone else.
The following solved it for me where [environment_name] is obviously what you name your environment.
Solution:
conda create -n environment_name python==3.9
conda activate environment_name
python -m pip install torch==2.0.1a0 torchvision==0.15.2a0 intel_extension_for_pytorch==2.0.110+xpu --extra-index-url https://pytorch-extension.intel.com/release-whl/stable/xpu/us/
I am unsure what changed that pip install is no longer sufficient, but this solved it for me. Thank you for your help!
Best,
Nate
Hairul_Intel
Hi Nate_,
Please have a try updating your pip to the latest version and try running the command again.
python3 -m pip install --upgrade pip
If the error persists, please provide the following additional information for further investigation from our side.
Instance ID:
Reservations details
Start time:
End time:
Hairul
Nate_
Solution:
Best,
Nate
Hairul_Intel
Hi Nate_,
Glad to know that your issue has been resolved and we appreciate you sharing the solution with the community.
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Hairul
