Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
Jupyter Lab Spawn Failed
amoghanshu
I get this error when trying to open jupyter lab. No idea what the issue is
AndrisG
I have the same problem. Something must have happened to the queueing system.
$ qstat -q
server: v-qsvr-1.aidevcloud
Queue Memory CPU Time Walltime Node Run Que Lm State
flex -- -- 00:05:00 -- 0 0 30 E R
extended -- -- 168:00:0 -- 0 0 -- E R
temp -- -- 03:00:00 -- 0 0 2 E R
jupyterhub -- 50:00:00 -- -- 0 0 -- E R
batch -- 100:00:0 24:00:00 2 0 526 20 E R
0 526
Sorry for the crippled text alignment in the snippet. It seems that new batch jobs are not allowed to start and are simply piling up.  New jupyter instances cannot get started for the same reason likely.
amoghanshu
Which machine configuration is the best for GPU based AI workload ? There seems to be a huge list of available machines.
Luwe_Intel
Hi amoghanshu,
Please specify which Developer Cloud product you are encountering issues with. Is it Intel® Developer Cloud or Intel® Developer Cloud for the Edge?
I have tested on launching both JupyterLab trainings of Intel® Developer Cloud and Intel® Developer Cloud for the Edge, and everything appears to be working fine.
Intel® Developer Cloud JupyterLab:
Intel® Developer Cloud for the Edge JupyterLab:
Could you kindly sign out and sign in to your account again, and then try to relaunch the JupyterLab to see if it works? We would also recommend you to use Incognito mode and clear your browser's browsing data (cache, cookies, etc.).
Do let us know if these methods work.
Luwe
amoghanshu
Hi Luwe,
 I was using Intel® Developer Cloud and issue is fixed now.
Thanks and Regards
Amogh Anshu N
AndrisG
Hi Luwe,
I had a problem with Intel Developer Cloud for oneAPI that looked exactly like the screenshot from amoghanshu. Anyways, the problem with this cloud is fixed now. The JupiterLab runs, and the queue is back to normal too. Thanks a lot!
Cheers,
Andris
Luwe_Intel
Hi @AndrisG ,
Thank you for reaching out.
Technical support for Intel® Tiber Developer Cloud for oneAPI is not available at this time. This forum is only supported by peers in the Community. We apologize for any inconvenience.
Please visit Intel® Toolkits with Priority Support for addition information or create an account on Intel® Developer Cloud.
Luwe
Luwe_Intel
Hi amoghanshu,
Glad to hear that it's working from your side. This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Luwe
