Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
No SSH Connectivity
tmb
I am setting up initial Cloud access, and was following the steps to setup the VSCode connectivity, which continually timed out.  I decided to troubleshoot in Putty and in Linux, figuring if I can get the basics to work, I can troubleshoot VSCode.
Anyway, I used puttygen to convert the private key so putty can use it. My connection string was given as:
ssh -J guest@146.152.232.8 ubuntu@100.81.93.137
So, I configured putty as:
Session: ubuntu@100.81.93.137 port 22 (SSH)
Proxy: SOCKS4 (also tried SOCKS5) 146.152.232.8, port 1080, username guest
SSH/AUTH: Putty private key
Running Wireshark, all I see is repeated SYN to 146.152.232.8 port 1080, no replies.
So, looks like never connects to the proxy.  Any suggestions?
TMB
tmb
Worth mentioning, I tried telnet to this address from Linux to see if there was any responses, and nothing on port 22, 80, 1080. Just repeated SYN and timeout.
TMB
Elmer_Intel
Hi TMB,
Before we further check the issue you raised, please provide the complete procedure you did to connect to VS Code. You may provide the error message along with a screenshot.
Furthermore, please attempt a normal SSH connection to the VM using a terminal to ensure the connection port is available.
If the error persists, please provide us your Intel® Developer Cloud instance details as follows:
Instance ID:
Instance Type:
Start Time:
End Time:
Elmer
Elmer_Intel
Hi TMB,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Elmer
