I am configured my rendering kit of one api as per its documentation. When I trying to connect the remote desktop using turbovnc its says that :
channel 5: open failed: connect failed: Connection refused
I found some solution on this forum that to add ssh tunnel configuration. I also added this configuration but still got the same error.
Please give me a solution to connect the remote desktop via turbovnc.
I'm using windows 10.
Hi PanthoMashreky,
Thank you for contacting Intel® Customer Support.
Sorry for the inconvenience. Unfortunately, technical support for Intel Developer Cloud for oneAPI is not available at this time. We suggest you use the oneAPI Toolkit that is available on Intel Tiber Developer Cloud. Let us know if you need additional help.
Sarven
Hi PanthoMashreky,
Thank you for your question. This thread will no longer be monitored since we have provided a suggestion. If you need any additional information from Intel, please submit a new question.
Sarven
