Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
331 Discussions
Ubuntu 22 Failed to start proxychains.service: Unit proxychains.service not found
kadirphp
I installed the proxychains plugin to open an application with a proxy on Ubuntu 22. I made the necessary proxy settings in the conf file, but I keep getting a timeout error when I run the application with the proxy. When I try to start the proxychains service, I get the error "Failed to start proxychains.service: Unit proxychains.service not found". I couldn't solve the problem, I reinstalled the operating system, rebooted the server, but I couldn't solve the problem. Interestingly, I get this error even when I start the service directly without editing the proxychains conf file and running the program.
Here are some additional details:
  • Proxychains version: 4.14
  • Operating system: Ubuntu 22.04 LTS
  • Application: Firefox
I have tried the following:
  • Reinstalling proxychains
  • Rebooting the server
  • Editing the proxychains conf file
  • Starting the proxychains service with sudo service proxychains start
I am still getting the same error.
Can you please help me solve this problem?
Thank you.
Dayang_Intel
Hi kadirphp,
To ensure we can assist you effectively, we would be very grateful if you could provide us with the Instance Details of your Intel® Developer Cloud as below:
Instance Type:
Instance ID/Resource ID:
Start Time/Created:
End Time:
The instance details can be found at https://console.cloud.intel.com/, in the Compute Instances section under My Instances. Click on your instance name in the "Instance Name" column to view instance type information. Please refer to the image below.
Dayang
Dayang_Intel
Hi kadirphp,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Dayang
