Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
292 Discussions
Unable to stop the instance
Compete2Cooperate
I am trying to stop the instance but could not see the stop button. Does anybody have any idea how to stop it ?
[screenshot attached; I would not see any Screen Shot 2025-01-31 at 13.41.38.pngstop button]
Erza_Intel
Hi Compete2Cooperate,
To do that, you need to log in to Intel® Tiber™ AI Cloud and then navigate to Compute and click on Instances. On the right side of the listed instances, you will be able to see the Start/Stop button, which you can use to stop the instance. Please refer to the image below.
Kindly be informed this Start/Stop button is only visible for Bare Metal (BM) instances and not Virtual Machine (VM) instances. If you would like to stop the instance, we would recommend you delete it. Please be aware that deleting the instance might result in losing any stored data. Therefore, it is best to back up your data before terminating the instance.
Hope this information helps.
Erza
Erza_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Erza
