Hi Deeps,
It seems that you are able to SSH into your instance via VS Code however, you are unable to execute the Conda command. From the screenshot you provided, it appears that Conda is not detected.
Please try to check if Conda is installed in your system. Type "bash" in the terminal to ensure you are in Bash and then try "conda --version". You can find more information in the Conda command not found discussion. (This is an external link and is not maintained by Intel).
To investigate further, can you provide us the Instance Details of your Intel® Developer Cloud instance as below:
- Instance Type:
- Instance IP:
- Resource ID:
- Created at:
Megat
Hi Deeps,
Thank you for your question. This thread will no longer be monitored since this issue has been resolved. If you need additional information from Intel, please submit a new question.
Megat
