Intel® Unison™ App
Support for the Intel® Unison™ App, a Multi-Device Experience software product that allows users to connect their devices and collaborate between them.
135 Discussions
Intel Unison is blocked
Jarkko333
Hey,
We cannot get Intel unison running because Windows tells us that "this app has been blocked by your system administrator" even though we haven't blocked it and we have checked all kinds of virus & firewall programs that they are not blocking it. Do you have any idea what might cause that problem?
Labels (2)
Senkuchan
Valued Contributor II
Kindly confirm that you are using an administrator account when installing the application. This error indicates that Windows has blocked the app from running because it found some issue with the app or its driver. This may be caused by various factors, such as:
• The app is not compatible or working properly with your hardware
• The app is restricted by your security settings or antivirus software
• The app does not have the necessary admin rights or permissions
Therefore, ensure that you log in as administrator or run the installer as admin. You can refer to this forum from Microsoft on how to fix this error: https://answers.microsoft.com/en-us/windows/forum/all/this-app-has-been-blocked-by-your-system/94de1926-30cc-4eae-b0db-d60456b29c0d
Also, verify that this application meets the system requirements for your device. You can check this link for the specifications: https://www.intel.com/content/www/us/en/support/articles/000092322/software/software-applications.html
Senkuchan
