Intel® Unison™ App
Support for the Intel® Unison™ App, a Multi-Device Experience software product that allows users to connect their devices and collaborate between them.
158 Discussions
Intel Unison reset
ronlee1030
Every time I run Ccleaner on my laptop Intel unison forgets my phone.  How can I prevent this
RobbieR_Intel
Hello ronlee1030,
Thank you for bringing this issue to our attention. I understand how frustrating it can be when CCleaner causes Intel Unison to forget your phone connection every time you run it.
Kindly answer the following questions:
  • Are you using the latest version of Intel Unison?
  • Where did you download Intel Unison?
  • Are you running CCleaner in manual or automatic clean mode?
  • Have you done troubleshooting steps?
We look forward to your response!
Robbie R.
ronlee1030
Yes I'm using the latest version downloaded from microsoft store.  I run CCleaner manually.  And I have no clue what troubleshooting steps there are to this other than seeing the connection gone on my laptop right after running CCleaner
RobbieR_Intel
Hello ronlee1030,
I hope you're doing fine. Thank you for answering the questions I have posted, this would contribute greatly to identifying what might be causing the issue that you are experiencing.
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
Robbie R.
ronlee1030
Here is that report
RobbieR_Intel
Hello ronlee1030,
Thank you for providing your SSU Log report. This would greatly help us determine what might be causing this issue.
Please answer the following questions:
  • Where did you download CCleaner? and what is its version?
  • When did this issue start? What changes were made on the system?
Robbie R.
ronlee1030
I downloaded CCleaner from ninite.com but updated from CCleaner website.  I'm on the most up to date version.  The issue began immediately after cleaning out junk files from the point I installed unison which was right after installing CCleaner
ronlee1030
Where is my phone connection info stored anyhow.  Maybe I need to add it to a list in CCleaner that prevents deletion somehow
RobbieR_Intel
Hello ronlee1030,
Thank you for the additional information. It seems that CCleaner may be removing certain files or registries related to Intel Unison's pairing information.
To prevent this from happening, please try the following steps:
-Open CCleaner and go to the Options Menu
-Select Exclude, then add Intel Unison's Folder or related files to the exclusion list so that they are not cleaned by CCleaner.
-Ensure that Windows Store Apps or anything related to app cache or registry cleaning is not affecting Intel Unison.
-After making these changes, try reconnecting your phone and running CCleaner again to see if the issue persists.
Kindly let us know if there are changes.
The folder for Intel Unison is located at C:\Program Files\Intel\Unison or C:\Program Files (x86)\Intel\Unison
Robbie R.
ronlee1030
I  dont see the app folder in either programs folder.  And its listed under the windows apps folder in start menu and not a legacy program
RobbieR_Intel
Hello ronlee1030,
Thank you for your response. Since it is located on the WindowsApps Folder, were you able to add Intel Unison to CCleaner's exclusions?
Entering C:\ProgramFiles\WindowsApps in CCleaner should exclude it from clean ups.
Robbie R.
ronlee1030
NormanS_Intel
Hello ronlee1030,
I'd like to suggest some additional troubleshooting steps for the issue you're experiencing. Please try the following and let us know the results:
Systematically remove all the checks in the settings of CCleaner, then add them back one by one to identify which setting is causing the issue.
Note: After our review, unchecking the “cookies” option for Internet Explorer in CCleaner should prevent Intel Unison from reverting to the setup page.
Norman S.
RobbieR_Intel
Hello ronlee1030,
I hope you had the opportunity to review the information we posted. At your earliest convenience, please let me know so we can determine the best course of action to resolve this matter efficiently.
Robbie R.
ronlee1030
I added the appdata folders with intel apps into exclude checked settings and still nothing is it a registry key getting deleted perhaps.  Or is there anymore spaces for unison to store app data other than the user app data local folder
RobbieR_Intel
Hello ronlee1030,
Thank you for your response. Since the solution didn't resolve the issue, I'll raise this case to my team for further review. We'll get back to you with an update as soon as we have more information.
Robbie R.
RobbieR_Intel
Hello ronlee1030,
Thank you for patiently waiting. I would like to confirm if you have also tried our Engineer's recommendation:
"Systematically remove all the checks in the settings of CCleaner, then add them back one by one to identify which setting is causing the issue.
Note: After our review, unchecking the “cookies” option for Internet Explorer in CCleaner should prevent Intel Unison from reverting to the setup page."
Robbie R.
RobbieR_Intel
Hello ronlee1030,
I hope you had the opportunity to review the information I posted. At your earliest convenience, please let me know so we can determine the best course of action to resolve this matter efficiently.
Robbie R.
RobbieR_Intel
Hello ronlee1030,
Robbie R.
