My problem is that i can get audio using my screen as a speaker. But i cant get audio through my headset. My headset is working fine for spotify etc but not the unison app.
Hello E789942,
Thank you for posting on the Intel® communities. I understand that you have some inquiries about the Intel® Unison™ app.
1. Did the app come Pre-Installed?
2. What is the operating system version and build?
3. What is the unison PC App version?
4. What is the iPhone model+ iOS version or Android phone and Android version, and mobile Unison app version?
5. What is the Computer Brand, model, and Intel Processor?
6. What is the intel Wi-Fi & Bluetooth adapter model used and version?
7. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
- Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
Deivid A.
1. No
2. Win 11 build 22621
3. Version u:10.9.2833/c:10.9.3461.0
4. Iphone 13 mini IOS 16.3.1
5. Standalone build, Processor: 12th Gen Intel(R) Core(TM) i7-12700F
6.
Intel(R) Ethernet Controller (3) I225-V 2.1.1.14
Intel(R) Wi-Fi 6 AX201 160MHz 22.200.0.6
Network Adapter(s): Bluetooth Device (Personal Area Network) 10.0.22621.1
Hello E789942,
Thank you for the information provided
Deivid A.
Hello E789942,
Thanks for your patience. In this case, the app cannot use USB wireless dongle. The audio issue might be related to a USB or Bluetooth headset.
Bear in mind that this app is intended for laptops EVO and should come pre-installed by the laptop manufacturer. It may not behave as expected on unsupported systems.
You can check the requirements and the user guide in the following links:
1. Requirements: https://www.intel.com/content/www/us/en/support/articles/000092322/software/software-applications.html
2. Guide: https://www.intel.com/content/dam/support/us/en/documents/software/Intel_Unison_UserGuide.pdf
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
