Intel® Unison™ App
Support for the Intel® Unison™ App, a Multi-Device Experience software product that allows users to connect their devices and collaborate between them.
Problem with pair
blatantq
Hi, I am trying to set up the Intel Unison app on my PC and my iPhone. But it is a bit sketchy, because it seems that I can not connect my phone and my PC trough the app, but I can send files. The files are sent to my PC, I even see a loading bar inside the Unison app, but cant interact in any way or see the history, calls, messages or anything else. But the file is transfered in the right directory and is alright, but the app itself, doesnt work ?
The error pops up if it says something like: Trying to pair your phone and PC, please confirm the bluetooth connection (I am from germany, I translated it).
If I try to connect them again, it either just loads a bit and returns to the start connection screen or doesnt even load and does nothing. All while the phone is connected already through Bluetooth with the PC.
I also unpaired the phone and tried again. I reinstalled the app on my phone and the PC, updated the bluetooth drivers, tried many different things. I Tried to pair it with my iPad, but the app says its no phone so not possible, so I can't tell if its the phones fault.
info picture:
JeanetteC_Intel
Hello blatantq,
I just need to ask if you are still able to use the Unison App on your phone but not able to use the desktop (PC) app? Or is it vice versa?
I will wait for your reply.
JeanetteC.
blatantq1
Hello, I can't pair my pc with my mobile I think so it doesn't show up in pc app gallery messages etc. but if I send a photo from my mobile to pc it gets saved to a folder in pc Intel Unison
blatantq1
JeanetteC_Intel
Hello blatantq1,
May I ask what your wireless/Bluetooth adapter make and model is? You may also share your system configuration so I we can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save (.txt). Attach the log file as you reply.
Please also make sure that your IOS version is iOS* 15.x and above.
Reference: What Are the System Requirements for the Intel® Unison™ App?
I hope to hear from you soon so I can proceed with further checking on this issue.
JeanetteC.
blatantq1
my bluetooth is tp link UB500
JeanetteC_Intel
Hello blatantq1,
Thank you for sharing these details. I'll further check on this and I will post an update once it's available.
JeanetteC.
blatantq
KitW
Having this exact same issue.
Everything is up to date, iPhone PC, etc.
Unison app is latest version u:20.28.8341.0/c:20.27.10835.0
If it does finally pair with my phone, it "unpairs" (if that's a word) within a few minutes.
I really want this to work. It seems to be so much better than PhoneLink.
Help!
JeanetteC_Intel
ello blatantq1,
The issue is still currently being checked. Please confirm the details below:
1. Can you pair another Bluetooth device with your desktop PC (e.g. BT keyboard and mouse, BT speakers, etc.)?
2. Is your iPhone also able to connect to other Bluetooth device (e.g. Bluetooth speakers/headphones, etc.)?
3. Are both devices (desktop PC and iPhone) connected to the same home/wireless network?
I hope to hear from you so I can proceed with further checking.
JeanetteC.
blatantq
JeanetteC_Intel
Hello blatantq1,
Thank you for the confirmation. I'll proceed with the further checking and will post an update once it's available.
JeanetteC.
blatantq
PhiPhi
I exactly have the same issue, impossible to have access to the messages, photos, notifications...
What is strange is that I can share documents from my device to the laptop.
This is not working between the ipad and the laptop neither.
Thanks!
JeanetteC_Intel
Hello PhiPhi,
I understand that you are facing exactly the same problem with the Intel® Unison™ app. However, I kindly request that you create a new thread for your case. This will allow us to focus on your specific problem and provide you with better assistance.
Sincerely,
JeanetteC.
JeanetteC_Intel
Hello blatantq1,
Good day.
From the picture provided, the iPhone in File Transfer is grey and disable. It might be due to iPhone and PC app are not the same latest version 20.27.x, USB BT issue and iPhone permission. iPhone General Settings > Bluetooth name must same as connected in PC'OS/DM Bluetooth and Intel Unison PC App settings.
Photo, video, media, gallery, messages, contact list and notification access must be "Always allow all" instead of "preferred setting or asking to allow access" from iPhone General settings. Both PC and iPhone status in Intel Unison PC App must "connected" then have same PIN number to pair successfully. I suggest checking iPhone General settings to allow all permission. Sharing the User Guide for pairing (page 20) and iPhone message limitation (pages 46-47).
Additionally, on about iPad issue. When pairing with iPad, you need to select Tablet icon and not Phone
I hope this helps.
JeanetteC.
JeanetteC_Intel
Hello blatantq1,
Have you checked my previous post/reply yet?
I hope to hear from you soon.
JeanetteC.
CalebStrong
Hey mate,
I made an account just to post the solution I discovered deep in a reddit thread.
It worked for me when pairing my PC and phone wouldnt work through the app, regardless of if I was paired already or not.
"For anyone having troubles connecting: If you have the same issue I did where it was saying bluetooth connection wasn't paired but still showed your device and the battery percentage here's something that got it to work:
On your phone try sending your PC a picture, if it worked then that means you can try the bluetooth pairing AGAIN and it should work this time. This has worked for both me and a friend. If it maybe says "Connection failed" try forgetting the devices in the bluetooth settings on BOTH devices and restart."
Hope that helps anyone struggling!
