Intel® Unison™ App
Support for the Intel® Unison™ App, a Multi-Device Experience software product that allows users to connect their devices and collaborate between them.
USB Headset
FLVisions
I utilize a High-end Shure Microphone / headset combination connected through USB. When placing and receiving calls, I can hear through the headphones, but get the "No active input sound device detected. Please connect and activate an input sound device such as a microphone." error. I have verified that Microphone is NOT working. It is my default Microphone. Any ideas?
Labels (2)
AceOfSpades45682
@FLVisions
I think there will be an issue with how your Shure microphone is being recognized by the system. But here are a few steps you can try to troubleshoot the problem. Ensure that the USB cable connecting your Shure microphone/headset to your computer is securely plugged in. Sometimes, loose connections can cause devices to not be detected properly. Make sure that your computer's USB drivers and the drivers for the Shure microphone are up to date. Outdated drivers can sometimes cause compatibility issues. Sometimes restarting the Windows Audio service can resolve issues with audio devices. You can do this by:
  • Pressing Win + R to open the Run dialog.
  • Typing "services.msc" and hitting Enter.
  • In the Services window, find "Windows Audio" service, right-click on it, and select "Restart".
Open Device Manager and look for any yellow exclamation marks next to your Shure microphone or any related devices. This could indicate a driver problem. If possible, try connecting your Shure microphone/headset to another computer to see if the issue persists. This will help determine if the problem is with the microphone itself or the computer setup. In Windows, check the privacy settings related to microphone access. Sometimes, applications may be denied access to the microphone, causing similar issues.
By following these steps, you should be able to diagnose and potentially fix the issue with your Shure microphone not being recognized as an active input device.
Perkins
