Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
Bonjour, Je me retrouve avec deux soucis sur mon serveur Intel unite .
nLeve1
Le premier souci est que au moment de l'installation de ce dernier, le service Intel Unite Maintenance tente de ce lancer et ce coupe aussi vite.
Le second souci est que si j'y arrive bien à installer ce produit sur mon server avec IIS, je ne peux me connecter avec l'identifiant admin (mdp : Admin1@ ) ,il se met à tourner en rond et n'atteint jamais la page administrateur .
Je suis dans l'impasse et ne trouve pas beaucoup voir même pas du tout de documentation concernant ces soucis .
Cordialement et merci d'avance
AndrewG_Intel
Hello nLeve1,
We would like to inform you that the support is only available in the English language and we are using translation software to check your inquiry.
In order to better assist you could you please confirm the following information?
1- Is this a new deployment of Intel Unite® or have you updated from a previous version?
2- Please provide screenshots and more details describing the errors you are experiencing:
3- Please confirm the Software versions running on the Server, HUB, and clients:
4- Also, make sure you comply with all the requirements and steps on the Deployment Guide for the Intel Unite® app.
Andrew G.
A Contingent Worker at Intel
AndrewG_Intel
Hello nLeve1,
We would like to know if you were able to check our previous post and collect the information requested?
If you need further assistance, please let us know.
Andrew G.
AndrewG_Intel
Hello nLeve1,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Andrew G.
