Hello, I have already installed a Unite 4.0 server on Windows server 2016. I can log into the admin portal. But when I run the hub app on NUC, I get the error 0x00542
I checked the error code. Then, I try to follow the error remediation to new a configuration, but I can not select a hub software version.
I click the dropdown list, but it did not show anything.
How can I resolve this issue?
Hello CChen187
Thank you for posting in the Intel Community.
· What is the Intel Unite® version installed on the HUB?
· Please provide me with the information requested on the following link.
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
Hello, the version of unite server & hub is 4.0.991.43.
The requested information is in the attached document.
If you need other information, please let me know.
Thank you.
Hello, I followed the steps you suggest, but it did not work.
I click the link to run the Hub, and still get the error 0x00542.
The certificate file I export is shown below
I found yellow warning signs on key Usage. Is this normal?
Thank you.
Hello, You are right. I did not update the cab file to admin portal.
Now the server, hub ,and client work fine.
Thank you very much.
