Intel Unite® App
Support for the Intel® Unison™ app
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
456 Discussions
Cannot run Logitech plugins for Unite 3.x and cannot found any for Unite 4.x
BMirz2
i need to use Logitech for Unite 3.x and 4.x. I have already installed on my 3.x, but when i run my client, it doesn't show any Logitech apps as ti supposed to. And i also could not found any for Unite 4.0.
Really need the help.
AndrewG_Intel
Hello BMirz2,
Logitech Plugin for Intel Unite® Solution works with version 3.x. There is no plugin version available for Intel Unite® Solution v4.x.
You can download the Logitech Plugin for Intel Unite® from the following links:
https://uniteappshowcase.intel.com/plugins/logitech/
https://downloadcenter.intel.com/download/26792/Intel-Unite-App-Plug-Ins
Also, please find below Logitech Plug-in Guide for the Intel Unite® app for installation instructions:
https://www.intel.com/content/www/us/en/support/articles/000026112/software/software-applications.ht...
For additional inquiries and support options, we recommend you to contact the plugin vendor.
Andrew G.
A Contingent Worker at Intel
BMirz2
Hi Andrew, I have download the plugin, and it is still the same as i downloaded earlier. It is only support for 3.x instead of 4.x. When Logitech 4.x plugin will be available. I have try install it on Unite Hub 3.x, and Client use Client 3.x, but no Logitech plugin appears on client side. We have the requirements as follow: * 10 classroom (40 students per classroom) connected in Testing Environment phase (prototype), >50 or >100 classroom (40 students per clasrroom) connected in Production phase; * Each student will have their own device installed with Unite Client; * Due to limited numbers of Lecture, they required for each Unite Hub in each classroom can act as Hub and Client; * Two-ways communication (Audio and Video, during QnA or Interruptions) is MANDATORY for this project. What is your best recommendations for this issue?; * Audio from presenter presentation is not distributed into viewer. Can you suggest how to make it works?; * How big bandwidth requires for those two scenarios? Each Classroom will have following devices: 1x Unite Hub 1x Interactive Projector or Touch Panel 1x Conference Cam Really appreciate for your help Best Regards, Barry Mirzanto
AndrewG_Intel
Hello BMirz2,
Thank you for your response.
Regarding Logitech support options and availability on when a version for Intel Unite® 4.x would be available, we recommend you to check with the plugin vendor.
The Intel Unite® HUB devices can play both the role of the HUB and Client on both 3.x and 4.x. This scenario is easier to handle with Intel Unite® version 4.x because of the added capabilities of being able to share HUB screen.
Regarding Audio from presenter distributed into the viewer, this feature is not supported by all platforms of Intel Unite® clients, only Windows, Mac and Chromebook versions (clients) support audio sharing.
Regarding recommended bandwidth, we suggest 50Mb for bandwidth, but please keep in mind that local traffic may vary.
Should you have additional inquiries, please let us know.
Andrew G.
AndrewG_Intel
Hello BMirz2,
If you need further assistance, please let us know. We will be glad to assist you.
Andrew G.
AndrewG_Intel
Hello BMirz2,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Andrew G.
