Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
Certificate Error - Don't have SHA-2 certificate
KGilp
I have run Unite Hub in debug and see the 'Blocking Insecure Certificate: SHA1_RSA... 'Could not establish trust relationship for the SSL/TLS secure channel with authority...'
I found the above in community and it would be great if I could skip the certificate check but my issue is I do not have this registry key on my hub. Unite is indeed installed but I don't even have the Unite sub under key Intel. Any ideas or help?
Hello kargy,
Thank you for bringing this to the Intel® Unite™ app community.
Please let me review this matter, I will update the thread as soon as possible.
Amy C.
kargy, could you please enter a couple of registry keys manually? Please see below;
Registry Keys: (machine)
HKEY_LOCAL_MACHINE\software\Intel\Unite\ DisableCheckCertificateChain (DWORD) [Set for SelfSigned Certificates, where if 1 = do not check certificate chain of Enterprise (Server Certificate)
HKEY_LOCAL_MACHINE\software\Intel\Unite\AllowInsecureCertificates (DWORD) [1 = certificate algorithm check should be skipped 0 = the enterprise certificate is forced to use a SHA2 certificate] Both
Amy C.
kargy,
If you need further assistance let us know.
Amy C.
