Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
Clients not auto discovering Unite server
schil
Not a DNS issue have verified.
This is a serious issue.
I need a user to be able to open the app on their laptop, as a guest
and not have to, at the start of a meeting , go configure an xml file
OR Set A DNS Suffix on a guests laptop we should not be touching a guest laptop this should be automatic..
in order just to allow them to connect to our server.
Intel take this on and fix this, there is no documentation that helps with this.
Hello Dersfam,
Thank you for joining the Intel Community Support.
I apologize for the inconvenience you are experiencing. In order to assist you better, please provide the following information.
What is the Intel Unite® App version?
How are the devices connected (wired, wireless, or both)?
What is the server configuration?
What is the laptop model?
What is the model of the device used as a hub?
Are you using Intel Unite® Small Business or Enterprise?
Wanner G.
schil
What is the Intel Unite® App version? the most current version I just installed it from your "SITE" Intel-Unite-Client-Application-Installer_6C0KT_WIN_3.2.82.42_A00
How are the devices connected (wired, wireless, or both)? BOTH
What is the server configuration? vm server, built to intel specs with more than adequate support
What is the laptop model? dell desktop Vostro 3905
What is the model of the device used as a hub? Optiflex 7050
Are you using Intel Unite® Small Business or Enterprise? enterprise
Hello Dersfam,
Thank you for your response.
We are already working on your inquiry on the following thread: https://communities.intel.com/thread/124730 https://communities.intel.com/thread/124730
In order to assist you better, this information will be forwarded to provide a solution to your issue as soon as possible.
Wanner G.
