Hello I am running out of time on my Intel Unite trial demo box so I would appreciate any support.
I can access my admin page without issue but the hub install can't grab a pin and I can't access the ccservice.asmx test page either.
Any help would be appreciated!
Hello Wanner,
Sorry for the late reply below is the debug info.
2019-02-26 3:15:17 PM Do Platform Check -
2019-02-26 3:15:35 PM 'BDK9S4CU' loaded Successfully. -
2019-02-26 3:15:35 PM 'GF26S5O5' loaded Successfully. -
2019-02-26 3:15:35 PM 'HSON0MMI' loaded Successfully. -
2019-02-26 3:15:35 PM 'SC7MOICU' loaded Successfully. -
2019-02-26 3:15:35 PM 'U9IB5AW7' loaded Successfully. -
2019-02-26 3:15:35 PM 'XS3DA1HG' loaded Successfully. -
2019-02-26 3:15:35 PM 'ZP7T2L1X' loaded Successfully. -
2019-02-26 3:15:35 PM Start RunPlugins: ValidateSku -
2019-02-26 3:15:35 PM BDK9S4CU LoadSmBiosData: Success -
2019-02-26 3:15:35 PM Error Running 'BDK9S4CU' Plugin: SMBios missing data: Maximum processor generation not met. Expected 7, actual 8. This platform should be checked by another Platform check -
2019-02-26 3:15:35 PM GF26S5O5 LoadSmBiosData: Success -
2019-02-26 3:15:35 PM Checking Type-1 tables -
2019-02-26 3:15:35 PM Corporation-Check Found: Dell Inc. -
2019-02-26 3:15:35 PM Product-Check Found. -
2019-02-26 3:15:35 PM GF26S5O5 Platform Check (SKU) is: Valid -
2019-02-26 3:15:35 PM Finish RunPlugins: ValidateSku -
2019-02-26 3:15:35 PM Error querying extended display - The parameter is incorrect
2019-02-26 3:15:35 PM Error getting device friendly name for display \\.\DISPLAY1 - The parameter is incorrect
2019-02-26 3:15:35 PM SizeChanged Right: Screen-> 1920Window-> 0 -
2019-02-26 3:15:35 PM SizeChanged Bottom: Screen-> 1080Window-> 0 -
2019-02-26 3:15:35 PM CFCInstance Init -> isClient: False -
2019-02-26 3:15:35 PM CFCClient INIT -> isClient: False -
2019-02-26 3:15:35 PM Calling CFCRX Init. Is Peer 2 Peer:? False -
2019-02-26 3:15:35 PM Slow Init Starting (Client) -
2019-02-26 3:15:35 PM CFCClient Slow Init -> _isClient: False -
2019-02-26 3:15:35 PM Slow Init Starting (CFCRX) -
2019-02-26 3:15:35 PM Creating singleton instance of WebRtcFactoryHelper... -
2019-02-26 3:15:35 PM Telemetry Init Failed: -2147418113 -
2019-02-26 3:15:35 PM Telemetry BeginSession Failed: -2147024809 -
2019-02-26 3:15:35 PM Telemetry Started -
2019-02-26 3:15:35 PM Telemetry: Hub_Start -
2019-02-26 3:15:35 PM SizeChanged Right: Screen-> 1920Window-> 1920 -
2019-02-26 3:15:35 PM SizeChanged Bottom: Screen-> 1080Window-> 1100 -
2019-02-26 3:15:36 PM SizeChanged Right: Screen-> 1920Window-> 1920 -
2019-02-26 3:15:36 PM SizeChanged Bottom: Screen-> 1080Window-> 1080 -
2019-02-26 3:15:36 PM Instantiating PeerClientFactory44 -
2019-02-26 3:15:36 PM ContentRendered Right: Screen-> 1920Window-> 1920 -
2019-02-26 3:15:36 PM ContentRendered Bottom: Screen-> 1080Window-> 1080 -
2019-02-26 3:15:36 PM Instantiating PeerClientFactory59 -
2019-02-26 3:15:36 PM Loading Profile -
2019-02-26 3:15:36 PM Getting profile -
2019-02-26 3:15:36 PM Enterprise Server Certificate Validation IsCertChainOk: False -
2019-02-26 3:15:36 PM Get Profile - Could not establish trust relationship for the SSL/TLS secure channel with authority 'servername'.
2019-02-26 3:15:38 PM Slow Init Complete (Client) -
2019-02-26 3:15:39 PM Getting profile -
2019-02-26 3:15:39 PM Enterprise Server Certificate Validation IsCertChainOk: False -
2019-02-26 3:15:39 PM Get Profile - Could not establish trust relationship for the SSL/TLS secure channel with authority 'servername'.
2019-02-26 3:15:42 PM Getting profile -
2019-02-26 3:15:42 PM Enterprise Server Certificate Validation IsCertChainOk: False -
2019-02-26 3:15:42 PM Get Profile - Could not establish trust relationship for the SSL/TLS secure channel with authority 'servername'.
Replaced servername fyi.
As far as I can tell I setup the certificate correctly following the enterprise setup videos. I did not create a dns entry but specified the servername in the hub install. Any ideas?
Good Morning Wanner,
Could you provide any instruction on how to edit the ccservice.asmx file so I can test that?
As stated above:
That was the issue I was trying to resolve originally.
