Intel Unite® App
Gain crucial understandings of the Intel Unite® App
459 Discussions
Guest access plugin issue in Enterprise
Hello all,
I have a issue with guest access function.
When I restart the HUB PC, I can't found the icon [Guest Access] in client. when I close the HUB software and run the HUB softeware again, is working well. and next restart HUB PC ,it's problem still.
Why?
thanks.
Hello sdh1984,
Please let me review your inquiry, I will keep you updated as soon as possible.
Amy.
Hi Amy
Below is the HUB Debug log for your reference.
Faild
5/3/2017 3:03:31 PM Error in load event in Plugin for Guest Access - Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
5/3/2017 3:03:31 PM Error loading plugin Guest Access Plugin. It will not be loaded - Object reference not set to an instance of an object.
Success
5/3/2017 3:32:36 PM Loaded Plugin: Guest Access Plugin -
5/3/2017 3:32:51 PM Plugin Manager - Loading assembly ... C:\Program Files (x86)\Intel\Intel Unite\Hub\Plugins\MetricsPlugin.dll -
After off the [Verify Plugin Certificate Hash] in admin portal.
HUB DEBUG Log :
5/4/2017 11:04:05 AM Error in load event in Plugin for Guest Access - No connection could be made because the target machine actively refused it 127.0.0.1:1234
5/4/2017 11:04:05 AM Error loading plugin Guest Access Plugin. It will not be loaded - Object reference not set to an instance of an object.
Hi All,
I have resolved this issue.
cause of the intel guess access default setting is Automatic(Delayed Start). It was been resolved after I change the setting from Automatic(Delayed Start) to Automatic.
/thread/113993 sdh1984, thank you for sharing your outcome. I am glad to hear you were able to fix this matter.
Amy C.
