Intel Unite® App
Support for the Intel Unite® App
456 Discussions
Guidelines for network configuration
Community Manager
Hello
I have an issue, with Intel Unite. My Issue occurs when I trying to connect to my hub with a client on a wireless network. When I connects to the screen with proper ID. i got an error that says that "the connection can not be established". I have tested my hub is configured correctly as it works on a wired network and then I have tested it on a linksys router with Wifi here it works fine too.
The problem occurs only when I log on to our enterprice network with a Cisco WLC .. Are there any guidelines for how we should configure our Cisco WLC for Intel Unite tiil to work? must be enabled for multicast or something else
Claudio_G_Intel1
Hi kristoffersc, i will need to have a closer look at your issue, please send me your contact information via private message if you agree so i can provide the help accordingly to your case through a call.
acuev
Hi i do have the same issue. Can you please help.
