Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
How do I change the background color and word wrap the instructions in the Protected Guest Access box.
AAhme64
I've tried all my possible best to change the gray background color to match the blue color but I don't know how to? Please any insight or direcyions will be greatly appreciated.
We're using intelUnite v4.x
Wanner_G_Intel
Hello AAhme64,
Thank you for submitting your question on this Intel® Community.
Try the following steps and let us know if you are able to modify these properties.
  1. Access the Admin Web Portal
  2. Then go to Device Management > Hub and client.
  3. Find the hub you want to modify and edit the properties available.
Wanner G.
AAhme64
This is all the properties available under the Guest Protected Access. [cid:image001.png@01D5FD22.60D7D2D0] You can only change the background color of the hub app. See screenshot below [cid:image002.png@01D5FD22.60D7D2D0] I want to change the background color of the Guest Access caption displayed on the hub when it’s started. See screenshot of issue below. [cid:image005.jpg@01D5FD23.112F8FB0]
AAhme64
posted a file.
AAhme64
Hub bgcolor settings
AAhme64
IntelUnite Guess Access caption screenshot
Wanner_G_Intel
Hello AAhme64,
Thank you for your response.
Please allow us to look into this inquiry.
Wanner G.
