Intel Unite® App
Support for the Intel Unite® App
456 Discussions
Intel Unite 4 - Admin page empty after installation
pstef3
I've installed Intel Unite 4 on Win2016 server with MySQL community (and SQL Express too) and self signed certificate. I see an empty Admin page on my browsers. What I need to check ?
Javascript console:
PQ000
This happened to me as well, did you install the URL rewrite thing?
pstef3
yes I've installed URL rewrite 2.1
TWebs
I'm having the same issue with Unit v4. It's installed on Server 2016 and the DB is on MSSQL 2017. I'm able to get to the Admin login page, input credentials, then get a 404 error on the next page. I have URL rewrite 2.1 installed as well. I had the earlier version of Unite (same server and DB) and everything worked fine. It's like v4 isn't all there.
Hope someone has an answer for this.
Leonardo_C_Intel
Hello TWebs Thank you for posting in the Intel Community. I recommend creating a new thread to isolate you case and system configuration, please make sure you add the information of the system model and specs, detail information of the problem that you are having, plus all the information that you have added to this thread, so we can get more information about the problem. Please also provide the following information on the new thread: • Fill up the information requested on the document attach. • Provide the MSIFO32 report file. • In order to help you better, I would like to gather more information about the configuration you have on the computer. Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility • Steps to save the report: 1- Run the utility. 2- Click on “Scan” to get the scanned system. 3- Once the scan is complete click on “next”. 4- Use the “save” option, save the report to your desktop. 5- To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box. Thank you; hope to hear from you soon. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
