My computer was recently imaged to Windows 10 Ver. 1903 . All the latest updates were also applied via the built in Windows Updates.
The application, upon launch prompts for a pin, after providing the pin it simply closes it. Wondering if this has been addressed.
Hello JGarc101,
Thank you for submitting your question on this Intel® Community.
We are still working on this issue. Try uninstalling the following KBs to restore the functionality of Intel Unite® App.
KB4511555
KB4506991
KB4514359
Also, please provide the Intel Unite® App version installed on your environment (Server, Hub, Client)
Wanner G.
A Contingent Worker at Intel
Hello JGarc101,
Were you able to review the recommendations provided?
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
Hello JGarc101,
Thank you for your response.
To better assist you, we would like to have the following information and log files.
HUB/Client computer details
- HUB manufacturer(s):
- HUB model(s) and SKU:
- Client model(s):
- Intel Unite® Client version:
- Intel Unite® HUB version:
- Intel Unite® Server version:
Log files:
Intel Unite® logs are the debug files the software automatically generates with the errors and interactions the devices that are running this application generate.
The Server saves the files at the following location: C:\Users\IntelUniteWebApiPool\AppData\LocalTemp
Files name are IntelUniteServerLog.txt, IntelUniteTransactionLog.txt, and UniteServerLog.txt
The Client and Hub logs are created by default and are called Unite.sql.
This file is located on C:\Users\User\AppData\Local\Temp
This file is a SQLite database, and it can be opened with any SQL Client but the DB Browser for SQLite is recommended.
Find all data generated by the application on the table, Logging.
Wanner G.
Hello JGarc101,
We launched Intel Unite® in-house, and we did not experience the problem reported on this thread. To better assist you, we would like to have more information about your environment to understand the reason why your setup crashes after installing Windows* 10 1903.
Recommendations
1. Please generate a system report with the Intel® System Support Utility (Intel® SSU) and attach it to this thread. This will generate the SKU and other useful details.
Intel® SSU Download link
Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
Click on the menu where it says "Summary" to change to "Detailed View".
To save your scan, click on "Next", then "Save".
2. Please attach the log files requested since they will allow us to debug your system.
Note: If you would rather not attach the log files to this thread, we can provide you with other options.
Wanner G.
I have the same exact issue and version numbers. My 1903 and 1909 clients all crash out, but the 1803/1809 clients for perfectly fine. What was the fix?
Hello JGarc101,
Thank you for the update.
We will close this inquiry. If you need further assistance, please post a new question. We will be glad to help you.
Wanner G.
