Intel Unite® App
Gain crucial understandings of the Intel Unite® App
This product has been discontinued. This board is currently read only and no longer accepting new posts. Learn more
459 Discussions
Intel Unite Hub PIN Lookup
PObre
Setting up Intel Unite for first time. Hub will not retrieve a PIN from the enterprise server. Seeing error message in debugging:
Get Profile - The HTTP request is unauthorized with client authentication scheme 'Anonymous'. The authentication header received from the server was 'Negotiate, NTLM'.
Hello obrejanp,
Thank you for contacting Intel Support,
I understand that you are having problems with the PIN lookup when using Intel® Unite, I apologize for any inconveniences this may have caused.
There are some steps we can follow to try and fix the issue, however, I need to gather some information first:
1) What is the model of the Hub?
2) What is the type of Intel® Unite? Is it enterprise or small business?
3) What is the version of Intel® Unite?
4) Where did you download the Intel® Unite?
After we gather these we will be able to provide the most accurate answer and/or steps to follow.
David V
PObre
Hi David
1) What is the model of the Hub? OptiPlex 7050
2) What is the type of Intel® Unite? Is it enterprise or small business? Intel Unite is set up as an enterprise. The server sits in a vm
3) What is the version of Intel® Unite? version is 3.2
4) Where did you download the Intel® Unite? Intel unite download page
Hi Obrejanp,
Make sure server, hub and clients are all connected in the same network, also try disabling the windows firewall on the hub...in addition try installing the newest version 3.3.
-Chris
PK9
Is there a solution for this issue?/
PK9
HI, I have 3.3.150.19 version. Firewalls are disabled in server and in hub. What do you mean in the same network?When i statically add server name in hub configuration file I have :
29.08.2018 11:40:15 Do Platform Check -
29.08.2018 11:40:50 'BDK9S4CU' loaded Successfully. -
29.08.2018 11:40:50 'GF26S5O5' loaded Successfully. -
29.08.2018 11:40:50 'HSON0MMI' loaded Successfully. -
29.08.2018 11:40:50 'SC7MOICU' loaded Successfully. -
29.08.2018 11:40:50 'U9IB5AW7' loaded Successfully. -
29.08.2018 11:40:50 'XS3DA1HG' loaded Successfully. -
29.08.2018 11:40:50 'ZP7T2L1X' loaded Successfully. -
29.08.2018 11:40:50 Start RunPlugins: ValidateSku -
29.08.2018 11:40:50 BDK9S4CU LoadSmBiosData: Success -
29.08.2018 11:40:50 No Corporation-Check required. -
29.08.2018 11:40:50 Checking Type-11 tables -
29.08.2018 11:40:50 Error Running 'BDK9S4CU' Plugin: SMBios missing data: Product-Check not found. -
29.08.2018 11:40:50 GF26S5O5 LoadSmBiosData: Success -
29.08.2018 11:40:50 Checking Type-1 tables -
29.08.2018 11:40:50 Corporation-Check Found: Dell Inc. -
29.08.2018 11:40:50 Product-Check Found. -
29.08.2018 11:40:50 GF26S5O5 Platform Check (SKU) is: Valid -
29.08.2018 11:40:50 Finish RunPlugins: ValidateSku -
29.08.2018 11:40:50 Application_DispatcherUnhandledException Obiekt docelowy wywołania zgłosił wyjątek.Odwołanie do obiektu nie zostało ustawione na wystąpienie obiektu. - Obiekt docelowy wywołania zgłosił wyjątek.
29.08.2018 11:40:50 Application_DispatcherUnhandledException w System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
w System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
w System.Activator.CreateInstance(Type type, Boolean nonPublic)
w System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark)
w System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
w System.Activator.CreateInstance(Type type, Object[] args)
w System.Xaml.Schema.SafeReflectionInvoker.CreateInstanceCritical(Type type, Object[] arguments)
w System.Xaml.Schema.XamlTypeInvoker.CreateInstance(Object[] arguments)
w MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstance(XamlType xamlType, Object[] args)
w MS.Internal.Xaml.Runtime.PartialTrustTolerantRuntime.CreateInstance(XamlType xamlType, Object[] args)
w System.Xaml.XamlObjectWriter.Logic_CreateAndAssignToParentStart(ObjectWriterContext ctx)
w System.Xaml.XamlObjectWriter.WriteStartMember(XamlMember property)
w System.Windows.Markup.WpfXamlLoader.TransformNodes(XamlReader xamlReader, XamlObjectWriter xamlWriter, Boolean onlyLoadOneNode, Boolean skipJournaledProperties, Boolean shouldPassLineNumberInfo, IXamlLineInfo xamlLineInfo, IXamlLineInfoConsumer xamlLineInfoConsumer, XamlContextStack`1 stack, IStyleConnector styleConnector)
w System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
w System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
w System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
w System.Windows.Application.LoadBamlStreamWithSyncInfo(Stream stream, ParserContext pc)
w System.Windows.Application.DoStartup()
w System.Windows.Application.<.ctor>b__1_0(Object unused)
w System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
w System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) - Obiekt docelowy wywołania zgłosił wyjątek.
w System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Obj...
