Intel Unite® App
Gain crucial understandings of the Intel Unite® App
459 Discussions
Intel Unite Hub with 2 Monitor setup. How configure Monitore right / left?
DMaih
We use a Intel Unte Hub (Enterprise Setup) in the first Conference Room.
The Hub use a 2 Monitore Setup.
If i want to present an the left Monitore the Präsentation starts at the right Monitor.
Windows setting on the Hub: Monitor 1 ist left Windows Monitor 2 is right.
A change of the cables and the Windows Display settings... Same Result. :-(
Any ideas?
Hello dmaihoefer,
Thank you for contacting the Intel community.
In this case, have you tried setting up the monitors at the Intel® HD Graphics Control Panel?
Right click on the desktop and clink on Intel® Graphics Settings and then click on display.
Once you are on the display screen you can choose what monitor will be on the right or on the left.
One will be the primary and the other monitor will be the secondary monitor.
Please let me know if that helps, if not I will be more than glad to further investigate for you.
Ivan.
Hello dmaihoefer,
Ivan.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
