I am trying to install Intel Server 4.0.991.43_A00. It appear fail when the installer is trying to create a table in the MySQL database.
I've tried a few different configuration but I still get the error.
As a added bonus, the installer is then broken after this attempt. The Organization and Organization Description are blank and locked. The installer won't let you get pass this point.
OS: Window Server 2016
MySQL: 8.0.13.0
Diego,
Thanks for the response.
Please see attached files. I had to compress the MSINFO32 report.
For Additional Information:
HUB/Client computer details - N/A
HUB manufacturer(s): - N/A
HUB model(s) and SKU: - N/A
Client model(s): N/A
Windows OS (provide Version number if Win10, and 32- or 64-bit) and update version: - Windows Server 2016 Standard Version 1607 OS Build 14393.2580
Intel Unite® Client version: N/A
If problem happens with Extended Display provide version: No
Intel Unite® HUB version: N/A
Intel Unite® Server version: 4.0.991.43_A00
If problem is related to database please specify MS SQL version: 8.0.13.0
Intel Unite® Small Business version (if applies): N/A
Intel Unite App Extended display driver version (if applies): N/A
HUB and Client Graphics Driver version and vendor: N/A
Number of systems affected: 1
Evidently, I can't upload two files for some reason. See below for Intel System Support Utility report.
This may not be related, but during install for me (also S2016, MSSQL) I failed to set up SQL in mixed mode and was Windows Auth only. I found that the service account Unite tries to set up is local only and I needed to have SQL in mixed auth to allow it. But, for me, this gave a specific error about failing to start a service through the GUI installer near the end of the install. YMMV. After switching to mixed mode and rerunning the installer, this resolved for me. The docs do specify mixed mode, but don't note that it is required.
Diego,
Thanks. Is there any update on a resolution?
I created a new VM with MySQL 5.7 not the latest version. This fixed this problem. I would recommend remove "or greater" from the "MySQL 5.7 or greater".
